Bunny Hops - How to - Printable Version
+--- Thread: Bunny Hops - How to (/showthread.php?tid=48399)
Bunny Hops - How to - tayto94 - 04-03-2013
Can anyone give a middling good explaination of how to do em???been trying for a good while , trying to get weight forward and using the rear brake but still only go as far as unloading the rear suspension
Bunny Hops - How to - M.F. Mall Cop - 04-03-2013
Clutch up a foot or two then throw your weight forward and up. I like to use the brake also. Gripping your tank with your legs as you throw forward helps. Its all about timing. Keep practicing and you'll get them. Here's some slow mo clips to help.
http://www.youtube.com/watch?v=aefq-w4SklQ
http://vimeo.com/63202011#at=0
2.16. Perfect demo.
Bunny Hops - How to - tayto94 - 04-04-2013
Cheers. Jason gets serious height. Don't think I'm giving it enough of a bunk before bringing it up. What does using the rear brake help by?
Bunny Hops - How to - Nateural - 04-08-2013
You clowns, you have to use the rear brake. Clutch it up and force your body up and forward as hard as you can at the same time. With the front tire being about 2ft ff the ground. As soon as you get to where you are as forward and up off the bike as much as possible stave the rear brake. You have to just know your bike and that comes with time. And Ollie with a skateboard is the same damn thing
Stab the rear brake*
Bunny Hops - How to - TLoke13 - 04-08-2013
In motocross guys airbrake. When they hit a jump you see their bike rock back and forth. They are using the rear brake to determine their pitch for a soft landing.
