bypass bas tip sensor 05 honda cbr600rr - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Welcome Center (https://stuntride.org/forumdisplay.php?fid=79) +--- Forum: New Member? Start here! (https://stuntride.org/forumdisplay.php?fid=27) +--- Thread: bypass bas tip sensor 05 honda cbr600rr (/showthread.php?tid=48253) |
bypass bas tip sensor 05 honda cbr600rr - stunter5 - 03-26-2013 just snip the plugs off twist red and green together leave white hang is that how u do it? bypass bas tip sensor 05 honda cbr600rr - maverickxp - 03-26-2013 Yup. Or just put a jumper wire in the plug so u don't have to cut ur harness bypass bas tip sensor 05 honda cbr600rr - Patient-zero - 03-27-2013 a paperclip does the job as well ^^ bypass bas tip sensor 05 honda cbr600rr - CORESLITE - 03-27-2013 Is this pretty much the same on every bike? bypass bas tip sensor 05 honda cbr600rr - stunter5 - 04-01-2013 also i was wondering on my 05 cbr600rr if i can get a mount for my speedometer on the right side of my tank since my bike doesn't start without the speedometer plugged in or is there a way to bi pass that 2 ? bypass bas tip sensor 05 honda cbr600rr - big ben - 04-01-2013 shouldnt have an issue with it plugged in or not. i dont have mine on at all. ziptie it to the top of ur cage |
