03 636 tos - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 03 636 tos (/showthread.php?tid=43999) Pages:
03 636 tos - PHOZE - 10-03-2012 Setting up my 636. Don't know where the tip over sensor is located. If anyone can provide me with this info and what I have to do to bypass it. Thanks. 03 636 tos - kruss - 10-03-2012 I run it the bike only turns off when its laying on its side for like 3 seconds. 03 636 tos - masters6RR - 10-03-2012 It's under the seat, bolted to the battery tray I believe.. Take it apart and remove the swing assembly deal inside... Reassemble, and remount, hoop up connector.... Go ride... 03 636 tos - SQUINTS - 10-03-2012 Quote:
03 636 tos - PHOZE - 10-04-2012 Quote:
03 636 tos - 0410r - 10-04-2012 Echele gasolina ensima y prendala that's how u fix it
03 636 tos - redstar - 10-04-2012 I also kept mine stock. Never had bike die on me and even stays alive for maybe 10 sec with it on the side. So I like it there just. 03 636 tos - Duane S. - 10-04-2012 Mine did have problems it would shut off and not come back on this happened to me at two comps so I stuck a beer coozie in it and I never had a problem again
03 636 tos - PHOZE - 10-04-2012 Que huelebicho lmao. I'll try that on yours parcero. Quote:
03 636 tos - theCOOK - 10-04-2012 Never had a problem with my 0304 and everyone told me to leave it. But on my 0506 I had to gut it. |
