how wide are your bars - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: how wide are your bars (/showthread.php?tid=43899) Pages:
how wide are your bars - lee majors - 10-01-2012 can some of you do a quick measurement and tell mehow wide are your bars from tip of one bar to tip of the other? also how long are eacj clipon? i think mine are too narrow. i'm runnin lsl. and from tip to tip i'm 29 1/4 my bars are 12 but they're mounted way inside the clamp. how wide are your bars - lee majors - 10-01-2012 only thing i like about them now is my si cage clears them so not as much worry about smashing my bars i guess but i'd really like them wider. discuss how wide are your bars - Nappy - 10-01-2012 My bike isn't with me, but I swear its around 34 maybe. I run vortex with Thorpe adapters. 11.5 inch barsI believe flush on he inside of the vortex... how wide are your bars - Righteous 1 - 10-01-2012 Mine are 30", tip to tip. Pics in my adjustables thread. Go make a guess for the giveaway....6 hours left!
how wide are your bars - lee majors - 10-01-2012 Quote:
how wide are your bars - WHEELIE - 10-01-2012 My Protapers are 31" tip to tip... how wide are your bars - -william- - 10-01-2012 34" wide overall for me, 14" long tube, i run a tigershark on an f4i and they rarely touch the ground how wide are your bars - Topek - 10-01-2012 How ever wide a standered size door my clipons are 1/2 inch wider how wide are your bars - kirny - 10-01-2012 This thread doesn't make sense depending on how turned in someone's clipons are the measurements will be smaller if u want an accurate measurement it should be from where te tube clamps to the tip of the tube how wide are your bars - ROWDY - 10-01-2012 30 inches wide |
