Brembo that u can switch from 18-20mm? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: Brembo that u can switch from 18-20mm? (/showthread.php?tid=43832) Pages:
Brembo that u can switch from 18-20mm? - ReCkLeSsRyAn - 09-27-2012 What master is that? Rcs? Any good for hb? Brembo that u can switch from 18-20mm? - kirny - 09-27-2012 It is not a switch in the mm it switches the pivot point there is the RCS 19 goes from 19/20 and the RCS 16 goes from 16/18 Brembo that u can switch from 18-20mm? - Duane S. - 09-27-2012 that ASV lever gives you three options 20/18 and a 19 on a brembo Brembo that u can switch from 18-20mm? - ReCkLeSsRyAn - 09-28-2012 Got one for 150 I see them online for like 350 so I think I got a good deal just don't know how it will work Brembo that u can switch from 18-20mm? - kirny - 09-28-2012 Which one did u get the RCS 16 or 19? Brembo that u can switch from 18-20mm? - ReCkLeSsRyAn - 09-28-2012 The adjustment say between 18 and 20 Brembo that u can switch from 18-20mm? - kirny - 09-28-2012 Then it is the RCS 19mm the 20 setting will be more stiff then the 18 this master will work great with a linked setup not sure if u will like it on just one 4 piston I know u and I had that convo before Brembo that u can switch from 18-20mm? - ReCkLeSsRyAn - 09-28-2012 Goin 8 pistons soon on the f4i Brembo that u can switch from 18-20mm? - kirny - 09-28-2012 Then I think u made a good choice with the 19 RCS that way if the 18 isn't stiff enough u can just switch it to 20 Brembo that u can switch from 18-20mm? - anarchist35 - 09-28-2012 sounds like a great combo to me....i rock an rcs 15 for hb |
