f4i clutch - Printable Version
+--- Thread: f4i clutch (/showthread.php?tid=43776)
f4i clutch - ReCkLeSsRyAn - 09-25-2012
need a new one b4 the halloween ride mine is slipping like hell... any prolems with buy after market?? if so what ones? or should i stay oem? best place to buy em?
f4i clutch - =BLEE= - 09-25-2012
Originally Posted by ReCkLeSsRyAn
OEM FO SHO
f4i clutch - anarchist35 - 09-25-2012
oem....if you do cheep out with aftermarket plates, use OEM springs or you could have a harder lever
Originally Posted by anarchist35
oem....if you do cheep out with aftermarket plates, use oem springs or you could have a harder lever
+10000000
right on guys thats all i needed to know i found a nice oem kit for decenlty cheap
f4i clutch - =BLEE= - 09-26-2012
Nice...
I'm sure you know this, but just incase it slipped your mind( like it did mine)...try adjusting your cable at the clutch arm and/or clutch lever. It might grab better for ya.
My clutch slipped BAAAD when I first bought my F-Fo-ez and
Unfortunately I wasted $$$ by ordering a new OEM clutch before I even tried doin any adjustments at the clutch arm...(I adjusted at the lever but it wasnt enough)
Anyway
Long story short...The adjustments worked and its still holdin strong 3-4years later.
f4i clutch - ReCkLeSsRyAn - 09-26-2012
Ya I hear ya its been slippin for a while now...pretty much ever since I switch to rsc... now it slips in first even...its cashed lol
I had problems when I tried the RSC also...it wasnt the RSC's fault,it was cuz I welded a 3/4" extension to my clutch arm...I didnt really even need the rsc cuz my pull was so butter with a MX lever..I just wanted to try it...
f4i clutch - rockstar - 09-26-2012
what oil do you run???
f4i clutch - sikgixxer750 - 09-26-2012
honda use to sell clutch kits back in the day. The steels and fibers for the 03 600rr clutch kit are the exact same as f4i just different springs. If someone has new old stock of the 600rr clutch kit u might be able to get it for cheap.
