Gas cap leaking ; dented tank HELP! - Printable Version
+--- Thread: Gas cap leaking ; dented tank HELP! (/showthread.php?tid=43216)
Gas cap leaking ; dented tank HELP! - BNasty - 09-07-2012
My dented tank is dented enough down to where it allows gas to leak out of the oem cap's vent. I used another gasket to try and help seal better but that isn't it. Are there any after market gas caps that seal well?
Gas cap leaking ; dented tank HELP! - redstar - 09-07-2012
Is it due to the oem cap coming up a little up front? So instead of it sitting flush with the cap the part that actually opens is slanted a little?
This topic has been covered a lot of times already. But the solution for most people is to just get a vortex gas cap.
Gas cap leaking ; dented tank HELP! - COOLIE - 09-07-2012
That ^ or water weld the shit out of it
Yea i didnt notice he current thread trending until i posted this. the cap face sits about 1/8th of an inch above the mounting rings surface. the gas leaks thru the vent hole and thru the keyhole/keyhole cover area. Im debating on plugging the keyhole cover area with some sealant and seeing if that helps. I also heard using RTV arouind the ring will keep the gas inside the ring.
Gas cap leaking ; dented tank HELP! - lucasstunts - 09-08-2012
clear silicone works for me
Gas cap leaking ; dented tank HELP! - Jfloryda - 09-17-2012
Originally Posted by coolierr
true that! got mad leaks and water weld is the shit
