quick bearing question. - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: quick bearing question. (/showthread.php?tid=42341) |
quick bearing question. - wastemgnt - 10-14-2026 \r\n \r\n I don\'t know the answer but I would guess no they at different rear ends all together?\r\n quick bearing question. - B-rup - 10-14-2026 \r\n \r\n Yes they are. Just re did my 03-04 street bike rims and my 05-06 lot bike rims. Go on allballs.com and you can check part numbers.\r\n quick bearing question. - COOLIE - 10-14-2026 \r\n \r\n Allballs.com tells you if the balls u got fit in the rims .. Loll\r\n quick bearing question. - tipper13 - 10-14-2026 \r\n \r\n just looked on ebay and looked to be the same.\r\n quick bearing question. - JohnnyP - 10-14-2026 \r\n \r\n Same wheel bearings front and rear from 03-2012 \r\n
quick bearing question. - tipper13 - 08-08-2012 rear wheel bearings the same in a 0304 as a 05+? |
