F4i dies in a wheelie, FI comes on - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: F4i dies in a wheelie, FI comes on (/showthread.php?tid=41988) Pages:
F4i dies in a wheelie, FI comes on - M.F. Mall Cop - 10-14-2026 \r\n \r\n Tip sensor bypassed? Probably a pinched electrical wire.\r\n F4i dies in a wheelie, FI comes on - zprt00 - 10-14-2026 \r\n \r\n Honestly I have no Idea, but I would assume that it\'s been bypassed. I\'m going to double check it. Probably have to get a new harness anyway. Now my leg hurts like hell and I can\'t move it. Damn bikes.\r\n F4i dies in a wheelie, FI comes on - wastemgnt - 10-14-2026 \r\n \r\n I would guess harness if its all fucked up and I don\'t think it is a good idea to put that much oil in\r\n F4i dies in a wheelie, FI comes on - zprt00 - 10-14-2026 \r\n \r\n I\'ll drain some of the oil then. From what it looks like, the tip over mod has been done. Green and red wire are cut off at the connector. I\'ll see if they\'re connected properly, but first need to cut a shit ton of electrical tape. Will get on it as soon as I\'m done with a take home final test \r\n
F4i dies in a wheelie, FI comes on - MiNi GuineA - 10-14-2026 \r\n \r\n Too low or high oil pressure will cause these symptoms\r\n F4i dies in a wheelie, FI comes on - zprt00 - 10-14-2026 \r\n \r\n Checked it just now and I actually overfilled it quite a lot. Out it goes. On the other hand, I rode for about two hours yesterday and didn\'t have that problem. I\'ll go through the harness later today anyway. Thanks for the input everyone.\r\n F4i dies in a wheelie, FI comes on - zprt00 - 10-14-2026 \r\n \r\n Can anybody tell me what the blue/white wire is for? I have the green and red connected as they should, but there is that blue/white and one of the white ones hanging loose. Headlight by any chance? not my photo btw. \n \r\n
F4i dies in a wheelie, FI comes on - M.F. Mall Cop - 10-14-2026 \r\n \r\n \r\n stuntride.com/vbstunt/showthr...wiring+diagramQuote: \r\n
\r\n \r\nWhite wire goes to the headlight relay. Blue/white is the lowbeam headlight. Im guessing someone cut it and bypassed it to run just highbeam light.\r\n F4i dies in a wheelie, FI comes on - zprt00 - 10-14-2026 \r\n \r\n Thanks Adroit, you always have the answer and are willing to help Imaginary rep to you BTW problem solved. The cables were loosely connected to the battery Cost me so much headache. At least I went over the harness, fixed some things up, tidied it up, did the radiator fan switch mod. And to top it all of, I made wheelies ![]() ![]() \r\n
F4i dies in a wheelie, FI comes on - lucasstunts - 10-14-2026 \r\n \r\n loose terminals? i have had the same problem. rides on 2 just fine but, sometimes in wheelies it bogs out and FI light comes on. the wiring is pretty messy so, you guys think that is it????\r\n |
