50 stunt handbrake - Printable Version
+--- Thread: 50 stunt handbrake (/showthread.php?tid=40902)
50 stunt handbrake - shawnmn - 06-24-2012
I have a 50stunt handbrake kit. the knob that you adjust the footbrake with keeps coming out of the tab that connects it to the handbrake. it sits on the tab rather then in the hole of the tab. finally the knob spun off the brake rod and i need to order a new one. any ideas on why the knob is not sitting in the hole of the tab properly? i set it up in the hole, then after about 10 minutes of rindin i notice it pops out and its not in the hole, its sittin on top of the tab. the spring is still there, so its not that.
50 stunt handbrake - tylerstunts - 06-24-2012
i had the same problem idk it does it. i just took my footbrake off and run just my hand brake and its fine.
50 stunt handbrake - nahi - 06-24-2012
should have a notch cut out to fit just right,if not put a nut behind it i guess...never had that problem and ive always ran em
a nut behind the nob should fix it, thanks
50 stunt handbrake - tylerstunts - 06-25-2012
still does it.. and it should have 2 nuts on the top
50 stunt handbrake - lucky13 - 06-25-2012
Use a nylon lock nut
still does it..
