Subwoofer/LOC - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: General Category (https://stuntride.org/forumdisplay.php?fid=3) +--- Forum: Automotive (https://stuntride.org/forumdisplay.php?fid=53) +--- Thread: Subwoofer/LOC (/showthread.php?tid=39346) |
Subwoofer/LOC - always.anthony - 05-04-2012 My sub is hooked up and everything, using a LOC (line output converter) currently i am only tapped onto my rear left speakers. Would it be better/different if i tapped into my right speakers as well (combined with my left). With my knowledge of electronics/audio. It shouldn't make a difference whether i tap into just the left or just the right. 1. because subwoofer is mono 2. because the frequency/current should be the same, even if i added sides right? I was just wondering if i'd get a better signal if i tapped both sides vs. just rear left. and how do i check to see if something is grounded properly, i have a multimeter and know to set it to ohms. one terminal to the ground on amp and the other to where i want to ground correct? Subwoofer/LOC - always.anthony - 05-04-2012 Everywhere i've looked said i should get less than 1 ohms for resistance, and on my multimeter it has -56.0 people were saying treat negative as positive as well, so can anyone explain whats going on? |
