CRF Radiator Fan Install - Printable Version
+--- Thread: CRF Radiator Fan Install (/showthread.php?tid=3845)
CRF Radiator Fan Install - FREDERATOR - 10-14-2026
\r\n \r\n im thinking about getting a 450 to stunt ,is it worth it ?\r\n
CRF Radiator Fan Install - 12oclocker - 10-14-2026
\r\n \r\n I would say yeah, get an X model or a model with lights & electric start, they are built better than the R models, larger fuel tank, heavier fly wheel, they come with lights, electric start, optional radiator fan, etc. I love motards, more than street bikes, sit down no handers are harder cause you got nothing to sit on, but they are cheaper to fix, and hold up in a crash a lot better, you also dont need a cage, the\'re light and easy to throw around under you. and you can jump loading docks, and other misc objects lol. I\'m selling my cbr to get another motard.\r\n
CRF Radiator Fan Install - DWJmoto - 10-14-2026
\r\n Originally Posted by 12oclocker\r\n View Post\r\n
Honda sells an optional Fan kit for the Radiator, I got the fan kit for a bit over $200, kinda high priced, but cheaper than a new engine since I\'ll be in the parking lot most of the time anyway, here\'s some pics of the fan install, if you\'ve ever notice the extra tabs on an \'X\' model\'s radiator, this is what there for, if you have an R model, you can probably get a radiator right side from and X model, but you\'ll have to run you own power lines, only the X model has the extra connector just sitting there waiting to be connected to the fan, the temp sensor mounts in the bottom of the radiator.
\r\nI had to cut my connection works radiator brace to install the fan, but it was worth it.
so you stunt the 250 I just aways thought that was prob the 450 in your pic\r\n
\r\n \r\n yep its the 250x, parking lot stuff on the 250x is butter...
\n the x\'s are geared much better than the R\'s, first gear is twice as slow as the R model, and last gear is faster than the R model as well.\r\n
CRF Radiator Fan Install - 12oclocker - 01-02-2009
Honda sells an optional Fan kit for the Radiator, I got the fan kit for a bit over $200, kinda high priced, but cheaper than a new engine since I'll be in the parking lot most of the time anyway, here's some pics of the fan install, if you've ever notice the extra tabs on an 'X' model's radiator, this is what there for, if you have an R model, you can probably get a radiator right side from and X model, but you'll have to run you own power lines, only the X model has the extra connector just sitting there waiting to be connected to the fan, the temp sensor mounts in the bottom of the radiator.
