Castrol 2 stroke premix oil,true or false? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Quads / Dirtbikes / Motard / Trials (https://stuntride.org/forumdisplay.php?fid=30) +--- Thread: Castrol 2 stroke premix oil,true or false? (/showthread.php?tid=38402) |
Castrol 2 stroke premix oil,true or false? - Lolletroo - 10-14-2026 \r\n \r\n Here in finland almost all of the peopple who own a ktm, husqvarna etc racing bike use either castroll tts (think its now called rs) or motul. I also use it on my 125 husqvarna. So from what ive seen and experienced its pretty much on of the best oils for 2-stroke mixes, because of its high quality.\r\n Castrol 2 stroke premix oil,true or false? - Juca - 04-09-2012 someone,used castrol as a mix oil for 2 stroke,i found on some website that castrol oil is junk for 2strokes, dude said that it tends to separate when the fuel gets cold... true or? " I used that for years but it like all castor oils tends to separate when the fuel gets cold (around 40 degrees). " "The cold temperature issue was mentioned in MXA about a year or so ago (I'll see if I still have the issue if so I'll let you know), If you keep your fuel inside at a moderate temperature you will burn it before it is an issue but if the fuel gets cold it doesn't mix well or stay mixed. I have experienced this since moving to Colorado."
