03 636 motor noise - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 03 636 motor noise (/showthread.php?tid=31670) Pages:
03 636 motor noise - Yamaha32088 - 09-11-2011 I just got done reshimming all of the exhaust valves and one intake valve on my bike along with putting in a new clutch all of them were way to tight but I only had to go down 1-2 sizes on all of them and as soon as I fired it up I heard this its a reallly loud rattling noise that I have never heard before I know that they are known for having loud valve trains but this doesn't sound like a valve issue it sounds like its coming from where the cam chain sits inside the motor I have checked the timing 3 times now and I know it is spot on the cam chain is tight the cam guides are in place I have about 160-180 psi of compression in all 4 cylinders what else can it be?????? I have dropped the oil 2 times now after running it for a minute or two to see if there was metal shavings in the oil but there was nothing and I also checked all the clutch components again and they all appear to be tight and in place. The bike seems to run awesome it fires right up and idles really good its just LOUD as fuck. 03 636 motor noise - navajowalks - 09-12-2011 Does it have a manuel adjusting or a factory cct? 03 636 motor noise - SQUINTS - 09-12-2011 if its manual.... turn that bitch in! 03 636 motor noise - navajowalks - 09-12-2011 If its a factory youtube ernievigil he just posted a video how to on the factory cct 03 636 motor noise - Yamaha32088 - 09-13-2011 No it's factory I just ordered a manual one because it's the only thing I can come up with as making the noise 03 636 motor noise - Yamaha32088 - 09-13-2011 I was watching my can chain tensioner with the valve cover off I would turn the motor over and can see it dipping back in and out it doesn't stay locked and rigid 03 636 motor noise - navajowalks - 09-13-2011 Maybe it broke?!? 03 636 motor noise - maverickxp - 09-13-2011 That doesn't sound like a cct but maybe you said u just adjusted your valves maybe one came loose 03 636 motor noise - JohnnyP - 09-13-2011 Do you know how to reinstall and reset the OEM CCT? Sounds like its isnt properly installed are you sure you have the spring in it? And did you install the tensioner body without the spring in it first, then install the spring to let it reset the tension?
03 636 motor noise - jewish636 - 09-14-2011 mine was making the exact same sound. Either adjusting ur stock one will work or just use the manual one. My 636 sounds like new now |
