water wetter IN engine ice? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: water wetter IN engine ice? (/showthread.php?tid=31615) Pages:
water wetter IN engine ice? - richd3000 - 09-08-2011 Can u add ww to engine ice? I was bored and googled it and all I found was ww vs. Engine ice stuff.. nothing about adding ww to engine ice. Seems like it would be the ultimate coolant... water wetter IN engine ice? - StuntBikeJake - 09-08-2011 It can be added to the mix yes because as I read it, the properties of each shouldnt affect the other.. dont know if it will be any better.. but I guess give it a shot and let us knwo water wetter IN engine ice? - Sunner - 09-09-2011 I dont think it would be any better at all, dont you add WW to water? And water is the best way to cool your motor anyway right? Doesnt make sense to me to do it. water wetter IN engine ice? - xxxfrankenstein406 - 09-09-2011 Its for antifreeze to since it has water in it. water wetter IN engine ice? - Sunner - 09-09-2011 Oh ok, didnt know you can mix it in antifreeze, never used it, still doubt it will work better than with just water. water wetter IN engine ice? - sQuiD FigHTer - 09-09-2011 Water is not the best way to cool your motor water wetter IN engine ice? - WHEELIE - 09-09-2011 I just use Honda Coolant... never have used WW or Engine Ice... ![]() Never have had a prob... water wetter IN engine ice? - xxxfrankenstein406 - 09-09-2011 Well distilled water is better, but if your outside temps get low then antifreeze ect is needed. water wetter IN engine ice? - richd3000 - 09-09-2011 I got some engine ice and am still waiting on my dcp rad cage so I can put on my new radiator... I seen the water wetter n it says can be added to water or antifreeze and helps and engine ice is a antifreeze so I figured they might mix... water wetter IN engine ice? - DerekS - 09-09-2011 I don't know about WW to Engine Ice. I know you cant mix regular antifreeze with it though. If you do this it can possibly gel up. The only thing your suppose to add to Engine Ice is water. But you wount get the "peak performance" from it unless it is straight engine ice. |
