Best clutch cable for F4i? - Printable Version
+--- Thread: Best clutch cable for F4i? (/showthread.php?tid=30565)
Best clutch cable for F4i? - Tech2 - 08-08-2011
Which clutch cable works best for the f4i with 929 front end,ho-hey top triple and flipped 636 clipons?--The stock f4i cable is a little bit to long and getting on my last nerves--I want a cable that comes straight out of clutch perch with no bends like the f4i, just a little shorter-Thanks
And yes I know I can get a custom cable made just like the f4i but shorter from motion pro-
Best clutch cable for F4i? - andyVE - 08-08-2011
subscribed
got the same problem...
Best clutch cable for F4i? - M.F. Mall Cop - 08-08-2011
Imo I like the f4i cable. nice and long so I can route it without any problems and have a nice smooth line.
Best clutch cable for F4i? - go diego go - 08-08-2011
stock
Best clutch cable for F4i? - ReCkLeSsRyAn - 08-08-2011
Post a pic
10cm shorter would be PERFECT!
Best clutch cable for F4i? - lee majors - 08-08-2011
is it routed inside your frame above the engine mount?
Best clutch cable for F4i? - Tech2 - 08-09-2011
stock routing definitly sucks for me because of my handlebar setup-Im around the outside of radiator with no tie straps-The tie straps make the clutch action suck really bad when bars are turned right-anyone that really knows about this problem should understand my delima---Everything is kinda ok when the bars are turned left or straight-- but turn right and forget it,..its suck dick city (no homo)lol---it sucked with my lower fairings off(the way im been running it for a while now) but I just put my lowers on and Im back off to suck dick city again but even worse now(no homo again)
Quote Originally Posted by andyVE
maybe a little more then that
