are the 2004 636 motor a interfance motor - Printable Version
+--- Thread: are the 2004 636 motor a interfance motor (/showthread.php?tid=28565)
are the 2004 636 motor a interfance motor - big will - 06-09-2011
need to no if the timing chain breaks is it going to bent the valves
are the 2004 636 motor a interfance motor - maverickxp - 06-09-2011
yes it will. even being off 1 tooth will bend valves. i found out the hard way
are the 2004 636 motor a interfance motor - Bortner - 06-09-2011
Not all the time depends on the circumstance but most of the time yes
are the 2004 636 motor a interfance motor - richd3000 - 06-11-2011
i ran mine with 1 tooth off for over a year... just ran funny, hada bad stutter about 3-4 grand. now its back in time and runs smooth n strong off idle.. i turned motor by hand before starting and no problem. they will run with a cam one tooth off.
