DRZ Rear Handbrake - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Quads / Dirtbikes / Motard / Trials (https://stuntride.org/forumdisplay.php?fid=30) +--- Thread: DRZ Rear Handbrake (/showthread.php?tid=27321) |
DRZ Rear Handbrake - bonafyd - 05-06-2011 Hey anyone running a rear handbrake on the DRZ400sm?? I wanna get me one but I have no clue where to start...any help is appreciated. DRZ Rear Handbrake - GIL with 1 L - 05-06-2011 My friend makes them on the other side of the outer bridge DRZ Rear Handbrake - bonafyd - 05-06-2011 Do you know how much & where by the outer bridge? DRZ Rear Handbrake - onelegstunter - 05-06-2011 get with bill at fti hes the man for this one. im running a 12 mm magura and its the best you gonna get with that lil caliper on there i promise.... im missing my right leg and rely on hb fully and i trust it with my life all day no fade issues. i faded on anything bigger.... but justin and jesse are using the 13mm magura thru the fti junction valve if your interested you can buy my brand new still in package junction valve and the ss brake line that comes with it from me and just buy you a 13mm magura if your running like that if not i know a kid on here made a dual braket set up using the chain gaurd then you can either run the same size caliper as is on there and a straight line back to it using the 12 mm. or a 13 if going thru junction.... hope didnt confuse you bro...... DRZ Rear Handbrake - GIL with 1 L - 05-06-2011 He is backed up till mid June DRZ Rear Handbrake - Zarrell - 05-07-2011 Does Bill still make those dual-caliper setups? I too need a new setup badly ha ha ![]() I had a caliper mounted where the stock rear rotor guard/mudguard was located but cracked the welds last week. Popped right off after hitting it too hard , still worked for straightline combos and smooth circles up until then though.
