hand brake help - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: 50 stunts (https://stuntride.org/forumdisplay.php?fid=21) +--- Thread: hand brake help (/showthread.php?tid=26480) Pages:
hand brake help - tdub - 04-17-2011 I put a rear hand brake on my 50 and I cant seem to get it right. I works but the hand lever is real spongy and I'd prefer it to be stiffer. The ajustment on the lever isn't long enough to pull out all the slack. Any suggestions on what I need to do? hand brake help - SQUINTS - 04-17-2011 Quote:
![]() ryan @ 50 stunt didnt send the spring for the rear line attachment, so i grabbed one from the local dealership. the spring helped keep the adjustment tight. the $5 adjustment screws that 50 stunt sells work well too i
hand brake help - dfwraptor - 10-17-2011 i have to pull myn exceptionaly hard for it to work. yours feel the same? hand brake help - StrictlyStunt - 10-17-2011 Might need new brake pads. Or an extended brake arm. hand brake help - tylerstunts - 10-17-2011 i just gota adjust them right. give it like 5 turns in on the nut. then on the perch have it all the way in. and then turn it out 3 turns and see how it is. hand brake help - tylerstunts - 10-17-2011 honda ruckus brake arms are cheap and better then blowing money on the ones at 50stunt. his are 40 or more and the ruckus ones are 12 to 15 bucks hand brake help - dfwraptor - 10-17-2011 i tried but its still just way to stiff. when i pull it it doesnt want to spring back just kinda sticks and feels like shit lol hand brake help - StrictlyStunt - 10-17-2011 try routing your cable a different way. I know the slightest bind can be night/day difference in the pull hand brake help - jack cooke - 10-17-2011 Quote:
hand brake help - tylerstunts - 10-17-2011 spray up the cable also wit wd40. |
