636 head removal? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: 636 head removal? (/showthread.php?tid=25549) |
636 head removal? - Dstunts - 03-28-2011 Does anyone know if you can remove and replace the head off an 04 636 without dropping the engine? 636 head removal? - jstein - 03-28-2011 if you left the lower engine bolt in and took the others out and rotated it down would be about the only way i would think. but then you gotta deal with the forks in the way and what not. probably be easier to just pull it so you have room to work 636 head removal? - Austin913 - 03-28-2011 no doubt about that! 636 head removal? - JohnnyP - 03-28-2011 Yes its possible
636 head removal? - loogie - 03-28-2011 just drop it...it takes me like 40 mins now that ive done it a bunch 636 head removal? - !!A2K!! - 03-28-2011 If your doing valves I'd pull it out, just a head gasket and id leave it in. 636 head removal? - Will215 - 03-28-2011 it takes like 30 mins to pull out and you dnt have to worry bout shit in your way while your workin on it, its not worth the aggravation jus pull it out |
