03 636 - Printable Version
+-- Forum: Welcome Center (https://stuntride.org/forumdisplay.php?fid=79)
+--- Forum: New Member? Start here! (https://stuntride.org/forumdisplay.php?fid=27)
+--- Thread: 03 636 (/showthread.php?tid=24140)
03 636 - 03636black - 02-24-2011
i went for a short ride today maybe 20 miles and when i got back i turned off my key n then went and turned back on to put it in later and when i turn the key when the computer boots up it sounds different is this anything to worry about? whats wrong with it?
03 636 - old man roger - 02-24-2011
what does it sound like ? normally the secondary butterflies will cycle and make some clicking noises and the fuel pump will prime and make a buzzing sound
idk oh to describe it it use to go zzzzz both times around but no it like clicks both times
i gotta be honest it sounds like you are hearing the secondary butter flies cycling and thats normal
oh ok thats good to hear lol
should it do it everytime?
ya unless you turn the key off and on real fast then some times it wont
not sure if it does it with the kill switch in the off position or not
03 636 - mrbigmike - 02-24-2011
OMR.. I have a similar problem but mine just sounds like that for longer than other 03s though. Someone told me maybe throttle bodies need replaced or the motor for the secondarys.. also my fi light comes on.. Any suggestions or ideas? Thanks bro
03 636 - $Evan$ - 02-24-2011
you have turbo lag
Originally Posted by mrbigmike
that doesnt sound like one i could diagnose over the computer sorry , only suggestion i can offer would be to try a friends throttle bodies and see it that fixes the problem
