600RR fender on 929 front end? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 600RR fender on 929 front end? (/showthread.php?tid=20963) |
600RR fender on 929 front end? - mdub4life29 - 10-14-2026 \r\n \r\n I believe so but u have to drill one Hole and u don\'t use one of the factory holes\r\n 600RR fender on 929 front end? - Raider - 10-14-2026 \r\n \r\n You sure can. You can use the top holes but you have to makea bracket for the bottom holes or just zip tie it to the fork leg. I have one on my bike, looks great\r\n 600RR fender on 929 front end? - Cjones - 10-14-2026 \r\n \r\n \r\n \nPic? thxQuote: \r\n
![]() \r\n
600RR fender on 929 front end? - Raider - 10-14-2026 \r\n \r\n Hereya go,not the best but you can see it none the less \n \n \r\n
600RR fender on 929 front end? - airbrushjohn - 10-14-2026 \r\n \r\n thanks man! i\'ll get one! awesome! \n \nand this is great cause its only 20 bucks \ninstead of my 954 fender is like colse to 100 bucks \nhttp://www.delkevic.us/?section=shop...erm=&order_by=\r\n 600RR fender on 929 front end? - Cjones - 11-26-2010 does a 07 600RR fender fit on a 929 front end? thanks
