best way to tell if forks are bent? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: best way to tell if forks are bent? (/showthread.php?tid=20452) Pages:
best way to tell if forks are bent? - richd3000 - 11-12-2010 I got a new front end that looks pretty straight but they are scratched n chiped and look beat up.. What's the best easy way I can tell if theyr bent any? Should I tryn roll it ona table? best way to tell if forks are bent? - Graveyard - 11-12-2010 What are they off of? If the tubes are chrome and they are bent the chorme will look distorted, I have a set off my F4i that are bent and i'm not even sure how it happend never hit anything or crashed real hard. If there inverted you should be able to tell pretty quickly. if you have them mounted on the bike put the axle through the forks without the tire and look at them from the side if the triple is square to the frame and the axle is not square you'll have your answer. just my
best way to tell if forks are bent? - Naarden - 11-12-2010 If its a possible bend, Ill take the fork apart. and roll each separate tube on a surface plate or something as flat as i can to see any wobbles. best way to tell if forks are bent? - Doodle - 11-12-2010 ^ this. best way to tell if forks are bent? - old man roger - 11-12-2010 there is a way to check with out taking them apart , it's not as precise but if they are bent a good amount it is easy to tell just by taking the front wheel and fender off and spinning the bottom of the fork 360 degrees .. measure the distance between the chrome part of the forks right where they enter the cast part , if they are bent the distance will change as you rotate the fork .. best way to tell if forks are bent? - big ben - 11-12-2010 +1 might even be able to do it w/o taking it off, just get at eye level best way to tell if forks are bent? - richd3000 - 11-12-2010 Awesome ideas! Yeah I got the 954 frontend n its been sittin in the garage. I went n slid them into the tripples and went to put front wheel on n axle thru it and it just seemed like they were to far apart at the bottom axle clamp.. Like it was missing a spacer almost, about a 5mm gap or so. I didn't tighten the axel bolt tho, maybe that would pull it tight? The front isn't on the bike yet due to needing seals. best way to tell if forks are bent? - Paul - 11-12-2010 with a run out gauge best way to tell if forks are bent? - Angry Mike - 11-12-2010 +1 on the run out gauge. best way to tell if forks are bent? - !!A2K!! - 11-12-2010 if it doesnt compress its fucked lol |
