F4i dogbone problem - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: F4i dogbone problem (/showthread.php?tid=19955) |
F4i dogbone problem - ADFreestyle - 10-28-2010 I just installed the Naarden SL200 suspension link on my f4i, went fine Now Im trying to lower my friends 01 f4i for him... I cant get the dogbone off, its stuck on the lower sleeve/ bearing. My first go around went smooth and it fell right out, this time its like that sleeve inside is a tad too big for the gap its been given and i cant get the dogbone to drop down. ANY IDEAS???
F4i dogbone problem - i_throw_nickels - 10-29-2010 wd40 or pb breaker take a shit and come back, it should be loose
F4i dogbone problem - =BLEE= - 10-29-2010 Do you have weight on your suspension,that could be makin it hard to remove? F4i dogbone problem - Naarden - 10-29-2010 Youll have to work it back and forth while prying on it, what happens is the steel inside piece sometimes rusts and rust expands, since its such a tight fit to begin with now its really wedged in there so you really gotta put some serious ass to it. Mine needed a little prying to get it out. You can also unbolt the 3 bolts down their connected to the engine if you have to. F4i dogbone problem - ADFreestyle - 10-29-2010 Unbolting it did the trick, thanks Naarden ur the best thing since sliced bread.... oh and u were wrong, only 2 bolts F4i dogbone problem - Naarden - 11-01-2010
