636 swingarm conversion - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 636 swingarm conversion (/showthread.php?tid=15737) Pages:
636 swingarm conversion - Matt_M - 06-20-2010 ive seen it somewhere before but cant find it. i changed the swingarm on my 03 04 636 to the 05 06. i was recently doing some service to my wheel and set the spacers down next to the 03 04 and i cant remember if the 05 06 spacer on the brake side is the longer or shorter one? ![]() i have a hohey dual caliper 4 piston bracket on it and the longer one makes it a pain in the ass to put the wheel into the swingarm and the shorter one is causing the 4 piston to rub the rotor?!any help would be great. 636 swingarm conversion - Matt_M - 06-20-2010 maybe i have the spacer on both sides messed up. fml! ![]()
636 swingarm conversion - Duane S. - 06-20-2010 the one thats solid goes on the left side and the one thats grooved goes on the right side thats if ur sitting behind the tire what kinda helps with that is if u take ur axle and flip it to the other side so that its easier to push it through the hohey bracket its a bitch coming from the brakeside go through the sprocket first 636 swingarm conversion - Matt_M - 06-20-2010 Quote:
636 swingarm conversion - old man roger - 06-20-2010 the cush drive spacers are the same on both bikes they are thick solid spacers with no lip the brake side spacers are different they are smaller than the brake side and have a lip , if you use one thats too small it will allow the swing arm to flex in too much when you tighten the axle and it should be clear it's the wrong one , the right one should fit snug and not really allow the swing arm to flex in when you tighten the axle 636 swingarm conversion - MVSBrendon - 06-20-2010 Quote:
636 swingarm conversion - old man roger - 06-20-2010 slacker
![]() the 03 04 part #92152-1254, the 05 06 is 92152-0244. my ol lady works at a kawi dealer and said if they are not the same part number they are different in some way. so in fact the cush drive spacers are different just for everyones knowledge. 636 swingarm conversion - old man roger - 06-20-2010 my bad the cush drives are the same size not the spacer ..sorry and i wasnt saying the brake side was the same size .. 636 swingarm conversion - Matt_M - 06-21-2010 Quote:
