my 636 wont start ... - Printable Version
+--- Thread: my 636 wont start ... (/showthread.php?tid=14910)
my 636 wont start ... - WEnis - 05-28-2010
ok i blew my motor on my 636 and bought a motor and a frame.. and i pretty much switched everything over to the good motor and frame... but i used the same wiring harness that came with the motor... and i just got everything hooked up and the bike will prime but when i hit the start button theres nothing any ideas?... anything will help... thanks
my 636 wont start ... - StrictlyStunt - 05-28-2010
put gas in it!
does it crank?
Check kick stand sensor & tip sensor
lol theres gas... and no... no crank at all
my 636 wont start ... - mb32 - 05-28-2010
sensors!
most likely the kick stand sensor.
my 636 wont start ... - StuntBikeJake - 05-28-2010
clutch switch, kick stand switch, tip over switch
i took out my tip over sensor... checked the kickstand wires and everythings good.. wheres the clutch switch at?
Quote Originally Posted by suicidl
the 2 wires that went into the stock clutch
do they come off the front of the harness? if so i didnt see anything that looked like it would plug in to the clutch switch
How do I do that lol
my 636 wont start ... - Ethiopian - 05-28-2010
Quote Originally Posted by WEnis
paper clip or connect the wires together.
I'm confused lol
