f4i starting issues! - Printable Version
+--- Thread: f4i starting issues! (/showthread.php?tid=11648)
f4i starting issues! - $CHANCE$ - 02-20-2010
So motor blew up, an i got another one an i put in an it barely turns over then just stops, ive changed the battery the starter an still doing the same all grounds an wires are all hooked up an still got nothing, an it wont even push start it still rolls in gear if you could help i would appreciate so much im trying to go to daytona friday an i really would like to get it going thank you!
f4i starting issues! - coasterboy - 02-22-2010
pull out the spark plugs and then try to turn her over. i worked on a bike one time and the cylinders were full of fuel. the fuel shot out of the bike ten feet in the air . the secound starter you installed was it new?
f4i starting issues! - Colin K - 02-22-2010
try push starting it in second gear (put a LOT of weight on the back tire when you pop the clutch). If it starts up, you might need your valves adjusted.
f4i starting issues! - ProZach - 02-23-2010
Originally Posted by coasterboy
pull the plugs and turn it over a few times, let any fuel or water or whatever come out. then drip a very small amount of automatic transmission fluid or even just motor oil down in the cylinders. let it sit for 30 minutes or so then turn it over again (with the plugs still out) just watch out cuz if it spins over fast its gunna shoot that fluid back out with some power lol. you can sit some rags over the holes to keep the mess under control. reinstall the plugs and everything else and see if she starts.
if the motor sat for a while it can lose all the lube on the cylinder wall and make it hard to spin over. good luck
