'o06 Air/Fuel Screw - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: 50 stunts (https://stuntride.org/forumdisplay.php?fid=21) +--- Thread: 'o06 Air/Fuel Screw (/showthread.php?tid=10084) |
'o06 Air/Fuel Screw - 99cbrXX - 01-13-2010 I found out recently that the mixture screw on my stock carb needs a special tool to change the setting. I thought about going to a stock crf 70 carb instead but i was curious to see if there are other 50 years where the mixture came with a normal screw that anyone can change, and if so, if i could buy that screw and just throw it in where mine is now. 'o06 Air/Fuel Screw - Crazy D - 01-18-2010 Honda did that to stock 50 carbs in 2006 . Kinda stupid . 'o06 Air/Fuel Screw - danger_dave - 01-18-2010 i believe that screw only controls the mixture at idle. if you want to change midrange throttle mixture and whatnot you have to take the needle out and raise or lower the clip. 'o06 Air/Fuel Screw - 99cbrXX - 01-18-2010 Quote:
'o06 Air/Fuel Screw - nj636 - 01-20-2010 don't you think a 20mm would be overkill for your stock 50cc? 'o06 Air/Fuel Screw - 99cbrXX - 01-20-2010 i sent an email to ryan. he said it be good. and then couple others i talked to said with a rev box it'd be fine. might put it off for a little while though. i hear i'd see a bigger improvement in my riding from gettin a set of street tires than i would tryin to rework a carb so think i'm gonna get the rubber first. my carb seems to be runnin pretty fair right now cause the temperatures are back in the usual florida range. 'o06 Air/Fuel Screw - Focer - 01-20-2010 yea tires first for sure |
