Kawasaki stunt er6 - build up ! - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.org/forumdisplay.php?fid=104) +--- Thread: Kawasaki stunt er6 - build up ! (/showthread.php?tid=47353) |
Kawasaki stunt er6 - build up ! - da Liks - 05-03-2013 foam for your seat is on the way! its not too hard so it will smooth out nicely under the upholstery.. Kawasaki stunt er6 - build up ! - Patient-zero - 05-03-2013 Sweet thnx Alex, i've cut out the hole already yesterday as a starter ^^ Kawasaki stunt er6 - build up ! - Patient-zero - 05-11-2013 Fixed the cracked gearing with a buddy, bike up and running again.. so up next : Got the Foam Aleks sent me, Glued it to the original seat and strapped it to let it dry: ![]() Sculpting ftw ![]() Gonna make a steel frame for the hole ![]() There, finished. ![]() ![]() Stretched the leather and went crazy with the stapler again.. ![]() ![]() Might look a bit funky, but the edge is nice, quite huge and gives back support ! The room between the edge and the tank is a bit smaller now, so sitting on it makes it feel rather snug and tight.. sweeeet
Kawasaki stunt er6 - build up ! - Patient-zero - 05-16-2013 Tank done by Paul from 101 bikes in Amsterdam : ![]() ![]() ![]()
Kawasaki stunt er6 - build up ! - Patient-zero - 05-17-2013 klaas finishing up the tank by molding a plastic tank inside the tank.. ![]() ![]()
Kawasaki stunt er6 - build up ! - Patient-zero - 05-23-2013 alrighty then, got the tank home.. did some wrapping myself, bike done ![]() ![]() ![]() ![]() ![]() ![]()
Kawasaki stunt er6 - build up ! - da Liks - 05-24-2013 getting there nicky!!! Kawasaki stunt er6 - build up ! - Patient-zero - 05-25-2013 Thnx aleksiej bike done as said above.. action pics down below ![]() ![]()
Kawasaki stunt er6 - build up ! - Patient-zero - 05-26-2013 aaaaaaaaaaaaaaaaaaaaaaaand, not that anyone gives a fuck, but some more pictures of today ![]() ![]()
