thermastat 636 replacement - Printable Version
+--- Thread: thermastat 636 replacement (/showthread.php?tid=44995)
Pages: 1 2 3 4 5 6 7 8
thermastat 636 replacement - Duane S. - 11-19-2012
Well now the over flow bottle is almost empty and nothing spit out
thermastat 636 replacement - old man roger - 11-20-2012
That sounds like the radiator wasn't full when the bike was hot so it pulled the fluid in from the overflow bottle as it cooled.
This could be caused by air in the system or a leak.
Top off the radiator and the overflow bottle and see if it runs cooler now.
thermastat 636 replacement - navajowalks - 11-20-2012
I concur
thermastat 636 replacement - Duane S. - 11-20-2012
yea when i get back from florida I'll put some more in and give it another shot before I go deeper into the engine.....cause my homeboy said the samething about that my res. tank is empty so I'll fill it up again
Fill your radiator first then your overflow..
Quote Originally Posted by navajowalks
yeah thats how I did it but I guess I didn't let it run long enough to pull the antifreeze threw
thermastat 636 replacement - Duane S. - 11-21-2012
Today I ran the bike set at my idle 4500 with fans on not moving it, let sit there and ran both fans. It took it 10 mins to hit 220 without riding it
Been tryin to get the air out
thermastat 636 replacement - navajowalks - 11-21-2012
Are you doing it with the radiator cap on or off?
On the side stand (kickstand)?
Have you checked your overflow hoses yet?
