09/10 winter project..... 2005 R6 stunt build - Printable Version
+--- Thread: 09/10 winter project..... 2005 R6 stunt build (/showthread.php?tid=12103)
Pages: 1 2 3 4 5 6
09/10 winter project..... 2005 R6 stunt build - jordanv3122 - 03-16-2010
haha hell ya bud! sounds like you are usin and abusin that wr! the 50 stunt non folding rider pegs will save your bike a ton. no more broken shifters and stuff lol. i am still waiting on my handbrake but im pumped cant wait to do combos lol
09/10 winter project..... 2005 R6 stunt build - Brandon L - 03-25-2010
Originally Posted by Tough Luck
Please tell me there is someone on here right now that can explain this to me. I'm doing this to my bike right now but im confused about what to do with hose #4 in one picture the hose is run from the crank case up to the "T" where #1 & #2 are connected then in the other picture the hose goes directly from the crank case to the hole on the back of the air box just like stock???????? what is the right way???????? HELP AM I JUST DUNB AND DON'T SEE IT????????????????
OK..... this pic below shows how it is stock (its just there so you know whitch one it is)
no this pic below is how it should look when its done.
1- cap off the port in the air box it came out of.
2- run a longer hose from the egine crank case breather to the T. like shown below. its a straight peice directly from the crank case to the T only.
hopefully the rest is self explanatory. let me know if you have any other questions. dont forget to cap off hole #1/#2 and cap off hole #4 in air box, and hook the rest of the tubes back up to it.
let me know if helps, and if you have any other questions.
09/10 winter project..... 2005 R6 stunt build - Tough Luck - 03-25-2010
Originally Posted by INSANECRAZZY
Dude you rock... thats whta i thought but wasn't sure... thanks for the help....
09/10 winter project..... 2005 R6 stunt build - !!A2K!! - 03-26-2010
your welcome fuckers! hahahahaha if you guys have ANY questions about any r6 or r1 get ahold of Cutler at c4....he is a yamaha mastermind. and he has to much time on his hands hahaha
09/10 winter project..... 2005 R6 stunt build - slidewayz89 - 04-20-2011
yo man what about the tip sensor mod on this 05 r6......
09/10 winter project..... 2005 R6 stunt build - Beto - 04-20-2011
I never bypassed my tip over sensor in either of my r6's and they both work fine.
09/10 winter project..... 2005 R6 stunt build - Brandon L - 04-20-2011
Originally Posted by slidewayz89
i didnt do anything with the tip/lean angle sensor on it. i didnt really ever have a problem with with not doing it either. i didnt do it on the yamaha supermoto i set up over this past winter either. i didnt have a problem with not doing it on this one either.
you can easliy do it though if you fill it up with a silicone, or glue the piece to saty in one spot, or do a wiring bypass so the pc thinks its good.
09/10 winter project..... 2005 R6 stunt build - alicia - 04-20-2011
that's a purdy stunt piece!
man its not the tip sensor my friends r6 bogs really bad when on idle dont know why.
