Stuntride motorcycle Stunt bike set up (for beginners) - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: Stuntride motorcycle Stunt bike set up (for beginners) (/showthread.php?tid=5448) |
Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-06-2010 BRAKES : Tip: Brake fluid absorbs moisture over time and becomes less effective. Replace brake fluid every one to two years and your brakes will preform the best they can. Motorcycle brakes are an art by themselves! Modern bike brakes have just an amazing stopping power, well beyond that of what the regular rider will encounter while riding. Motorcycles have up to two brake fluid reservoirs, one for the front, usually found on the handlebars and one for the back. Both should be checked regularly. Topping up should only be done from a new, sealed bottle as brake fluid tends to absorb moisture over time. If your brake pads are thin and due for replacement. Beware - brake fluid, if spilt on paintwork eats right through to the bare metal. Also check the thickness of the brake pads. If you allow them to go right down to the metal your brake disc will be damaged resulting in an unnecessary and expensive replacement. Fitting braided steel brake lines will increase the performance of your brakes by roughly 50% Replacing front and rear brake pads : Tip: If you are unsure how to replace brake pads then have a mechanic do it for you. It is worth the cost as it is in the best intrests of your safety. Feel free to bleed your own brakes as that is a easy operation to do. Replacing stock or worn brake pads is the quickest way to get increased braking power out of a tired system. Various manufacturers make all kinds of different types of replacement brake pads for today's motorcycles. Some claim to last longer, while others claim to give more feel and braking power. However, be forewarned that the manufacturer of your motorcycle put a lot of time and effort into developing your braking system, and there is no telling what a different type of pad material might do to your rotors or how well different pads will work with the overall design and setup of your bike. If you have any doubts, then stick with genuine factory parts. Removing the calipers from the rotors is the first step in checking your brake pads. In dealing with your front disc brakes, first remove the Front Caliper two main bolts that attach the calipers to the forks. Once the calipers are free you can slide them off of the brake discs and inspect the amount of pad material and look for anything out of the ordinary. If there is less than 1/8 inches of pad thickness left then they should be replaced. Internals of Front Caliper : Once the calipers are free from their mounting locations, it is time to disassemble them and remove the brake pads. On this particular setup there is one threaded metal pin that holds one side of the pads in place. The other side of the pad rests in the casting of the brake caliper. Removing this pin will free the pads and they should just fall right out. Notice the metal clips inside the caliper just beneath where the pads sit. These metal clips provide pressure on the pads to keep them from moving around inside the caliper. It is a good idea when you are working on your brakes to replace these clips. It would be foolish if you spent all this time and effort to have something so simple and cheap screw things up. Internals of Rear Caliper : Once the two mounting bolts have been removed, the caliper should easily slide off the rotor. Inspection of the pads is the same as the fronts. The rear pads are smaller because less braking power is required. The rear pads are held in place by one bolt on one side of the caliper and are held at the other end inside the casting of the mounting bracket that the caliper is bolted to. Be very careful to make sure the new pads are firmly mounted in the caliper and are held securely at both mounting locations. If there is any doubt, check them again! Otherwise, they could fall out while you are cruising down the side of your favorite canyon road and ruin a perfect day, causing you to crash into the guard rail and go flying off the side of a cliff. Not a pretty site. Once the new pads have been assembled into the calipers and everything is torqued to spec, it is time to bleed the lines. How to bleed motorcycle brakes : Tip: Any brake bleeding kit will do just fine but make sure you have a small bucket to put the tiny brake bleeder fluid container in as it is very likely to overflow. It is actually not very hard to bleed (renew) your own motorcycle brake fluid. This should be done at least every 2 years. Or when the brake fluid turns from clear to a brown to black colour (darker it is, the worse it is). Brake fluid will eat away at plastic and paint, be sure to cover any paint or plastic that may get splashed with brake fluid. Wipe any spilled fluid with the rag and lots of water. Step 1: Make sure you have the tools to bleed your brake fluid. The tools you require will vary, but generally this is what you will need: A. Wrench/Spanner (average 10mm) B. Brake bleeding kit (rubber fitting, clear hose, small container) C. Brake fluid overflow container (to put the brake bleeding kit small container in) D. Rags E. Brake Fluid (check what type of brake fluid you need for your bike. e.g. DOT 3). Make sure to buy enough brake fluid in the DOT type you require. (500ml should be more than enough). Step 2: Attach the brake bleeding kit to the brake fluid nipple located on the brake caliper. Step 3: Loosen the nipple so the fluid is free to flow down the brake bleeding kit tube and into the small container Step 4: Remove the master cylinder cap (top) so you can monitor and refill more brake fluid into the master cylinder as you bleed the brakes. Step 5. Pump the brake lever so the old/new brake fluid is forced through the tube into the brake bleeding kit fluid container Step 6: Keep the volume of the master cylinder constant (near full) as to not have it empty. Keep pumping on the brake lever until the fluid coming out is clear (rather than the old brown/black colour). Step 7: Once all the tiny air bubbles are gone hold pressure on the brake level and re-tighten the brake fluid nipple to close it off. Step 8: Replace the master cylinder top cover. Step 9: Remove the brake bleeding kit from the cliper and use the rag with water to clean up any spillage. Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-09-2010 MAGURA RADIAL BRAKES : MAGURA RADIAL 190. Purely a cosmetic item and the dream part for many high end freaks. Radial pump milled from solid metal for a brilliant feeling during braking and shifting. A pure pro tool for super bikes, supermotos and the street, impressively combining ergonomics and metering. Space saving, technically perfect design offers clear advantages:
![]() MAGURA RADIAL 195. The compact hydraulic brake or clutch fitting with strong price-performance ratio. MAGURA brand quality that pays for itself. Easily attached even in tight spaces by tilting the pump. Perfect for metering, stabile pressure point. No surprise that it is the standard fitting for MAGURA brake systems. All components are also available individually. The RADIAL 195 optimises the performance of many bikes as a brake or clutch. Also, as a clutch it is standard for the KTM Duke 990 and the currently top rated BMW HP2 Sport.
Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-09-2010 HOW PREPARE MOTORCYCLE FOR SHIPPING : Before your motorcycle movers arrive for pick up, you should prepare your motorcycle for transport. First, check your motorcycle for pre-existing damage. By documenting the condition of your bike, you can avoid problems in case of an insurance claim. To check for and record damage:
Remove all loose items from your motorcycle. Your motorcycle mover is not responsible for these items, and if accessories are lost or damaged they will not be covered by insurance. Make sure your motorcycle is in good working condition. While it will be avoided at all costs, sometimes your carrier may need to drive your motorcycle to move it or transfer it to a new motorcycle transport trailer. Fix all mechanical problems and write down any special operating instructions. For successful motorcycle moving, make sure to:
Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-10-2010 TAG "PRO" BARS : Pro Bars : With this set up you can run any top mount damper you want and have more adjustability than any other db bar set-up. They place the bars just below center of your fork legs. Bars can be rotated in the clamps, the clamps can be rotated on the fork legs and the clamps can be reversed to put the bars an inch and a half farther forward for larger riders. Leave your factory top clamp and damper on, these simply clamp on to your fork legs. Tag Metals T2 (used exclusively as they have the thickest wall dimension in the industry) bars are machined with a retention groove for safety. Tested extensively for durablility (some people would say crashed repeatedly), the bars are replaceable and available individually in this product category in case you really throw it down the highway. If you are replacing your existing dirt bike bar set up than you'll be fine, but if you are installing these on a stock F4i be advised you'll need longer brake lines as well as longer (or re-routed) clutch and throttle cables. Price : $ 270.00 Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-10-2010 05 600RR Dual Quad handbrake bracket : (INCLUDES 80" Brake Line, caliper bracket and crush washers) This kit is out of control. After being on the street for just a couple of months it's already got a reputation as the hot set up for precision rear brake control. This kit uses a right and left side 4 piston front brake caliper found on the 929's, the 954's the F4i's and F4's. You will have to source calipers (which are usually sold in pairs) as they don't come with the kit. Why would you want to use a 4 piston caliper for your foot brake? Control and feed back at the lever. Face it, your stock rear caliper is sloppy. It slides on pins, so you have to press your foot pedal several inches just to take the slack out and get it to bite, then it's all about vaguely smashing the pedal until the bike starts to do what you want. A fixed position 4 piston caliper eliminates all of that. You actually get feed back at the pedal, a stiffer pedal and reduced effort. For those still chasing balance point this won't mean much, but for the rest of you it will mean more precise riding, making everything from no handed sit down wheelies and beyond more predictable and controllable. In case anyone brings it up, the bottom caliper is far enough inside the wheel that it can't possibly contact the ground in the event of a crash. Don't forget, your pads overhang the rotor on this kit. This is an important issue, because the total thickness of the pad material on each side is greater than the thickness of the rotor. This means that if you run an unmodified stock pad, the pads will eventually touch together where they aren't contacting the rotor. When this happens, you have no handbrake. Your options are to either grind the pad away where it does not contact the rotor and breathe brake pad dust, or purchase our pre-machined pads. Leave the lung cancer to us, the pads are the same price you'd pay nearly anywhere for them and you have more usable surface area of the pad contacting the rotor than you would if you butcher them up yourself with a 5" grinder. Select the option below to have the stock Honda pads or Carbone Lorraine pre-machined pads shipped with your order. You can also order the SBC HH pads (as well as the Carbon Lorraine pads) in the "handbrake accessories" section of the site, but you get less pad thickness and they are a lesser quality product, so why bother. ![]() ![]() Price : $170.00 http://www.fullthrottleinc.net/store/ Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-10-2010 Dirt Bike Bar clutch line and brake line kit : ![]() This kit includes a +4" clutch cable and a +4" dual line steel braided brake line kit. This is a necessity when you are installing dirtbike bars on your sportbike. Having the additional cable and brake line length will allow you to use the factory routing instead of trying to re-route the cables and deal with the agony of coming up just a little too short. Please specify the model and year of your motorcycle in the notes section when you are placing your order (it will come up when check out). If you are riding a bike that has the throttle assembly seperate from the right hand switch box you can simply rotate the throttle assembly forward to get the extra length you need out of the stock cables. On the other hand, many sportbikes utilize a combined right hand switch box and throttle assembly. In that case you should look at our other kit that includes the throttle cables as well. Price : $125.00 http://www.fullthrottleinc.net/store/ Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-10-2010 Pit Bull Steering Stabilizer Kit : ![]() Our hydraulic, top mount Pit Bull steering stabilizer features center-hub design for even load distribution and long life. Its multi-paddle design has special valving for instant-on hydraulics without free play. The bracket system has three advantages: 1) it allows freedom of movement in all three directions of translation and all three axes of rotation to protect the internal mechanism, 2) it eliminates virtually all free play, and 3) it hinges out of the way to allow quick access under the fuel tank. U.S. Patent number 6,899,208. Other patents applied for. Sold complete with bracketry for bike. Bracket kits also available without stabilizer. Current colors available are black, blue and red. Price : $424.95 www.pit-bull.com Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-10-2010 JANEKEXTREME MUFFLERS : ![]() ![]() ![]() ![]() ![]() Its made from stainless steel and its all polished. They are made for : 636 O3-04 , F4i , F4 , F2 , F3. Contact : stunter13 (Click on name) Price : $200 + Shipping Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-10-2010 OMR SUBCAGES : ![]() Available subcages: Honda :
Tech :
![]() ![]() Click here to contact >> old man roger The original folding peg subcage! >>>click here to see why i only sell folding peg subcages <<<< Don't ride on this : ![]() And don't wait till this happens ![]() Get one of these instead ![]() below is a picture that explains why i only sell folding peg subcages if you look close you can see that the tabs were ripped right off this subframe and that is what can happen if the pegs on your subcage are solid ...folding pegs are the way to go.
Stuntride motorcycle Stunt bike set up (for beginners) - Juca - 01-11-2010 Scotts Stabilizer Kit : The road bike kits are machined to match exact features of your bike. Each mounting kit is specific to a certain bike. This is one of the best products you can put on a road bike, improving steering, stability, handling and safety considering all the hazards one can face on the road. We have meticulously assembled each kit so they come complete with all the necessary hardware to mount your steering stabilizer. Most kits require only minutes to install. The kit pictured and the majority of kits include: a Stabilizer, link arm, Triple Clamp nut, Frame Bracket, Tower Pin, TC Damper Mount, instruction manual and applicable hardware. You can view many of the assembled kits on this site via the "photos" tab. ![]() Price : $ 479.00 www.scottsperformance.com |
