Make over on my 50...From poo to AWESOMENESS! - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: 50 stunts (https://stuntride.org/forumdisplay.php?fid=21) +--- Thread: Make over on my 50...From poo to AWESOMENESS! (/showthread.php?tid=5992) |
Make over on my 50...From poo to AWESOMENESS! - Crazy D - 10-14-2026 \r\n \r\n \r\n The rear caliper link does not work . You need to post the full link .Quote: \r\n
\n \nThat rim has no brake panel . you will need the right type hub panel on the right side for it to work . \n \nA regular stock crf50 brake panel fits into the hub on a stock wheel , but it also slides in the notch on the swingarm . \n \nAnd the caliper will need to be mounted to a bracket . And the bracket will have to work on a stock crf50 swingarm . \n \nMost chinese knockoffs with rear discs , also have different swingarms . That is what that rim assembly is designed for . \n \nAnd i\'m guessing that fluid resivoir on the lever would fall off or crack when you drop the bike and the bars hit the ground .\r\n Make over on my 50...From poo to AWESOMENESS! - 702BOYZ - 10-14-2026 \r\n \r\n Nice bike playa.\r\n Make over on my 50...From poo to AWESOMENESS! - THETEDEFFECT - 10-14-2026 \r\n \r\n kudos\r\n Make over on my 50...From poo to AWESOMENESS! - T-Dubby - 10-14-2026 \r\n \r\n haha sick man!\r\n Make over on my 50...From poo to AWESOMENESS! - KaoSquad - 10-14-2026 \r\n \r\n damn that rear brake setup looks good. Does it work at least 10% better than stock cause that would be awesome.\r\n Make over on my 50...From poo to AWESOMENESS! - Thatgirl - 10-14-2026 \r\n \r\n \r\n \n Quote: \r\n
\n \nWho did them seats? they are !! pm me please!\r\n
Make over on my 50...From poo to AWESOMENESS! - buddy lenzin - 10-14-2026 \r\n \r\n My friends girlfriend in Abbotsford BC. \n \nShe cut and stiched it, and I wrapped it.\r\n Make over on my 50...From poo to AWESOMENESS! - rsizzle6 - 10-14-2026 \r\n \r\n could be sweet!\r\n Make over on my 50...From poo to AWESOMENESS! - SEAN_PARRISH10 - 10-14-2026 \r\n \r\n Are You Going To Put A Bolt In Your Brake Lever .. Or R U Gonna Leave That Ziptie On There ... Not So Safe...\r\n Make over on my 50...From poo to AWESOMENESS! - SEAN_PARRISH10 - 10-14-2026 \r\n \r\n HERES SOME PICS OF ALL THE FIDDYS I BUILT.. I HAVE HAD ABOUT 5 OF THEM ... AND THIS THREAD IS MAKING ME WANT ANOTHER ONE .... \nMY FIRST ONE \n ![]() \n \n ![]() \n \n \n ![]() \n \n ![]() \n ![]() \nBACK IN THE DAY WHEN IT WAS FUN \n \r\n
