Fiddy Repair and Maintenance. - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: 50 stunts (https://stuntride.org/forumdisplay.php?fid=21) +--- Thread: Fiddy Repair and Maintenance. (/showthread.php?tid=59) |
Fiddy Repair and Maintenance. - billz - 02-11-2014 thanks CheddarBob the brake pedal setup looks straight forward but how do you go about installing the rider pegs. it sits underneath the motor and on top of the cradle portion of the frame. do i have to pull the motor out.. Fiddy Repair and Maintenance. - CheddarBob - 02-12-2014 i wouldn't think you would have to pull the motor but then again i don't have a biletware cradle frame, what i have is 4 12mm bolts that bolt up to the crankcase on the underside of the crankcase and i looked up pics and can't find a good one on a biletware cradle frame to 100% but it looks like it does the same on the biletware cradle frames if you have a skid plate you're gonna have to take that off thats the only reason i can of that would make it so you couldn't see the bolts from the underside. oh and NP hope this helps. |
