Tires & pressure? - Printable Version
+--- Thread: Tires & pressure? (/showthread.php?tid=47011)
Pages: 1 2 3 4
Tires & pressure? - StrictlyStunt - 02-13-2013
Quote Originally Posted by !!stretch!!
Pilot road. 28psi or shitty vee rubbers that constantly leak air...start with 30 by the e.d of the day im on the rim
I feel you. I usually start with 30 and end up with 20 by the time I'm loading up. Can't beat free tires tho lol
Tires & pressure? - jrose152 - 02-13-2013
i ran used track tires for 60$ a pop mounted and i think i ran around 26psi for rear
Tires & pressure? - Raider - 02-13-2013
Quote Originally Posted by StrictlyStunt
Go to a tire shop and buy a little can of the black bead sealant. It's like $15 and will last forever. Whenever I have a used tire that has a small bead leak I mark the tire, pop the bead, and smear some of that for about a 12" section around the leak, reseat the tire and hold it at like 50psi for a while. BOOM, no more leaks
Tires & pressure? - navajowalks - 02-13-2013
Quote Originally Posted by BU_Stunts1
cool thanks bros im around 32psi, anybody know the pros n cons on the d616, and why some people run there tires backwards?
I'm on my first one now... And I like it... Drifting was easy... They probably flip the tire when one side is worn out cause they can drift to the right...
Tires & pressure? - Tattooty - 02-14-2013
ya i stick with 28-35psi rear. front is a few psi short of whatever they put in at the dealer.
Tires & pressure? - Guido - 02-15-2013
I run the psi game!
