Graveyard Custom Stunt Tanks!! - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Companies (https://stuntride.org/forumdisplay.php?fid=97) +--- Thread: Graveyard Custom Stunt Tanks!! (/showthread.php?tid=43823) |
Graveyard Custom Stunt Tanks!! - ONEwheelPHIL - 10-04-2012 Just got my R6 tank back today after a Graves Customs makeover and it's badass!!! The turn around was only 1 week and I'm very happy with his communication and the way my tank came out. He keeps you updated with pictures and ask for input or feedback the whole time. I opted for a 2" round lip with the cap as far front as possible, I also had him reinforce the rear tank mounts. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Graveyard Custom Stunt Tanks!! - MiNi GuineA - 10-04-2012 Nothing but quality!!! Killer job man! Graveyard Custom Stunt Tanks!! - BLEED - 10-06-2012 Shits dope Graveyard Custom Stunt Tanks!! - *MeatballStunts* - 10-12-2012 Can anyone explain what to do with the lines inside the tank... theres 2 right? So the one line you move to the top of the tank and put a check valve on it but what do you do with the other line? whats that line do? Graveyard Custom Stunt Tanks!! - Petarded - 10-12-2012 liked... sick work bro Graveyard Custom Stunt Tanks!! - *MeatballStunts* - 10-12-2012 Anyone? Graveyard Custom Stunt Tanks!! - ONEwheelPHIL - 10-12-2012 Pm Mini or Graveyard, they would know... Graveyard Custom Stunt Tanks!! - MiNi GuineA - 10-12-2012 It does nothing, its part of the stock system no longer being used Graveyard Custom Stunt Tanks!! - Duane S. - 10-12-2012 so the tank doesn't build up pressure?
Graveyard Custom Stunt Tanks!! - MiNi GuineA - 10-12-2012 No.. the OEM system vented from the stock gas cap, this modded tank only needs 1 check valve and a extended tube relocated to the top of the tank. When the bike is in a wheelie or on the normal riding position it vents and when the bike is in a stoppie gravity keeps the gas from coming up the vent tube. The second the bike is back to a normal position is will vent again |
