righteous easy pull on drz?????? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Quads / Dirtbikes / Motard / Trials (https://stuntride.org/forumdisplay.php?fid=30) +--- Thread: righteous easy pull on drz?????? (/showthread.php?tid=30435) |
righteous easy pull on drz?????? - onelegstunter - 08-04-2011 Gonna order now thanks rush it to me lol righteous easy pull on drz?????? - RUTHLESS RAH - 08-04-2011 my bad i have a 450x....the R parts wont work...i ordered R parts before and it didnt work righteous easy pull on drz?????? - onelegstunter - 08-04-2011 i just ordered both the long lever one in green and a silver spacer so make sure that my order ships together cuz ur website wouldnt allow me to order together only seperately so i think im getting charged $8.00 too much lol but no trip if you catch it and send together in same box as an added bonus lol righteous easy pull on drz?????? - onelegstunter - 08-04-2011 lol i just red my receipt lol sorry .... its cool righteous easy pull on drz?????? - DJFireUSA - 10-19-2011 Looking for following setups... search not working Drz400sm Cage Hb Anything else? righteous easy pull on drz?????? - Stubbz63 - 10-20-2011 nothing available for them man, cage is made one of nothing in production but PM onelegstunter he might be able to send ya pix of his he made. handbrake probly junction valve is only thing available i dont think theres a DCB out there. skip the cage get stiff driver pegs and axle pegs for protection and handgaurds, build your own roundbar and get an RSC you should be good. righteous easy pull on drz?????? - DJFireUSA - 10-24-2011 Yeah, the hand guards already did their job. Bike now has axle sliders front and rear. The friggin rear brake needs some serious detuning. Works too damn well. Don't dare use it unless i wqnt to break the rear loose. Accidentally touched brake pedal ever so slightly while buried in a turn and low sided. Obviously not a big deal (low siding) but shouldn't have happened. My fault... bad foot placement on peg so when leaned over, road bumped foot which put pressure on rear brake pedal and rolling on the ground i went. Hmmfff righteous easy pull on drz?????? - DJFireUSA - 10-30-2011 Sometimes it's the simple things that you over look... What are the chances that my rear brake sensitivity is related to a worn tire? Common thinking would cause me to think the more worn, the more rubber in the contact patch, more traction. Thoughts? righteous easy pull on drz?????? - Larse - 11-01-2011 That could be the problem, just try a less worn tire to see if there's a difference? Used to lock up my front tyre at stoppies when the tyre was worn, fresh tyre and almost no locking up the front wheel
righteous easy pull on drz?????? - *MeatballStunts* - 11-01-2011 ordering another rsc tonight for the drz. Im ordering without the spacer and Ill see how it works and order the spacer if i need it. I dont think i should need it |
