636 bog when hot - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 636 bog when hot (/showthread.php?tid=28009) |
636 bog when hot - richd3000 - 06-03-2011 N fuckin ford 5.4 motors eat coils like candy... 636 bog when hot - Gerlach - 06-03-2011 thanks I'll keep that in mind
636 bog when hot - ToKwik - 06-03-2011 If you think the pump is a problem, make sure you do a pressure test. I recently had a 636 that had been acting up. Everything was checking out "ok" then the last dyno run came out lean. Turns out the pump was putting out about 20-30 psi, plenty of volume for it to operate, but the bike needs 45psi to run correctly. New fuel pump solved this particular problem.
636 bog when hot - OneWheelHump - 08-15-2012 I Know this is a year old thread but just curious if you ever discovered the issue ? |
