My Righteous Clutch Review - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: My Righteous Clutch Review (/showthread.php?tid=7347) |
My Righteous Clutch Review - krazykyle85 - 09-24-2009 No reason to change what works. I've had the same brembo since I started stunting. My Righteous Clutch Review - krazykyle85 - 09-24-2009 AWESOME! good to know that it wasnt meant to be like that hahahaa i will send back the perch today and wait to see what i think till i get it back.. is there any way i could get a longer lever made? ..like a inch longer and some more material machined off the perch? then it would be purrrrfect My Righteous Clutch Review - Team NLR - 09-24-2009 Thanks Kyle your set up looks the same as mine and i was wondering if the clutch lever was gonna be able to pull around my hand brake.. I will also wait for new version then purchase
My Righteous Clutch Review - john LegionST - 09-24-2009 Agreed, and I really cant say much cause you obviously murder Clutch/HB with your current setup... but just from my many years of experience, everyone who i convinced to try mounting the HB as far in on the clipon as possible has loved it and said it helped them with a lot of tricks and control. I think ur right thou about it needing to fit everyone's setup and was glad to see that you and Righteous could work together on this, in the end it will only help everyone! My Righteous Clutch Review - UpOnOneLa - 09-24-2009 awesome reveiw kyle!! ![]() righteous ur the man!
My Righteous Clutch Review - Righteous 1 - 09-24-2009 Nice! ![]() Longer levers are still about a month out. If you end up thinking you'll want to keep it after you get the RIGHT perch, ........pull out the grinder and do work, bro. I made it thick for ultimate strength, and there is plenty of material that can be removed for cutomization. That was my thinking.
My Righteous Clutch Review - Righteous 1 - 09-24-2009 Thanks, bro. Just trying to do business the right way.
My Righteous Clutch Review - Tice - 09-24-2009 on the brembo you can just swap the banjo and bleeder and you have a clutch side master for about 100 less.......lol My Righteous Clutch Review - Tice - 09-24-2009 What I find the most interesting in this thread is Kyles clutch side grip! Props to Righteous for taking criticism and working to fix the problems that have arisen. Set up looks good and I look forward to putting one on my bike when the time comes. My Righteous Clutch Review - krazykyle85 - 09-24-2009 like i just sent you... on pm... what makes you think we want to put a grinder to our 80 dollar clutch perch. the whole clamp area should be machined down when the perch is fixed or a longer lever should be offered. because like i have shown. it is not able to be used like a msr in its current form. the lever doesnt even reach my grip. with my msr i have the whole flat finger are covering the grip.... thats kinda a big diffrence what do you think about this? should i just send the whole think back and stick with msr? ![]() i cant wait a month for a lever to use this perch...
