my 06 636 build - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.org/forumdisplay.php?fid=104) +--- Thread: my 06 636 build (/showthread.php?tid=42230) |
my 06 636 build - YSRRider - 10-14-2026 \r\n \r\n It doesnt work because glass beads are round, sure it will clean away dirt, paint and mild rust. The beads are not aggressive enough to remove any of the surface material leaving you with virgin substrate. On aluminum they fold the surface metal over into itself as if you were working pizza dough. Any soils on the metal have now been pushed down into metal such as oil and whats gonna happen to that oil when you apply heat to it? Again......... another reason why HACK coaters double coat shit. The 2nd coat hides it all. Using glass beads is cheap and most cabinets handle them with ease. To use a better media like Aluminum Oxide you need a blast gun that can handle the abuse and you need 2-3 times the CFM of air to be efficient since its a heavier material. When you are working in your garage and all you have is a 40gal Craftsman air compressor, you have no choice but to do it the wrong way.\r\n my 06 636 build - 802bouffard - 10-14-2026 \r\n \r\n I didn\'t know that, but like I said seems to be holding just fine, I figured I would clean it up since his glasses are thick as hell but he sure can see colors, I do it all at my uncles shop so I don\'t have to pay to blast at least so can\'t complain since my bike still looks purdy minus the cage\r\n my 06 636 build - YSRRider - 10-14-2026 \r\n \r\n \r\n Dont waste your time. Focus on what you do best, make money and pay a pro. For what it will cost you to start up and do it half way correct, you could pay a pro to powder coat 5 complete bikes. You will also be like the ugly kid that lives down the street that is the only kid in the neighborhood with a swimming pool and its the middle of summer.Quote: \r\n
my 06 636 build - 802bouffard - 10-14-2026 \r\n \r\n \r\n ^^^^ hahahaha so fucking true about the swimming pool Quote: \r\n
to that\r\n
my 06 636 build - YSRRider - 10-14-2026 \r\n \r\n lol no joke. People that I hadnt talked to in years started coming around.\r\n my 06 636 build - A-MAN - 08-02-2012 GOT the bike from flores: . White and red theme Tygershark cage not sure what subcage i will run. dual throttle setup thumb and twist dual fan Going to vinly wrap the plastic with a graffiti theme. |
