636 bog when hot - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 636 bog when hot (/showthread.php?tid=28009) |
636 bog when hot - beardo - 05-31-2011 a bad fuel pump was causing me several different problems, and low end bog was one of them. 636 bog when hot - -Loco- - 05-31-2011 german brand called "LIQUI MOLY" injection cleaner
636 bog when hot - JohnnyP - 05-31-2011 Cool Im going to look for some of that, but if I cant find it does anyone recommend a different brand? Ive always wanted to try some FI cleaner 636 bog when hot - beardo - 05-31-2011 Barrymans b12 636 bog when hot - loogie - 05-31-2011 also...according to OMR there is a cleanable filter inside the pump itself..might be worth taking a gander in there sometime for shits and giggles. 636 bog when hot - beardo - 05-31-2011 good info right there^^^ 636 bog when hot - -Loco- - 06-03-2011 ok so this POS is doing the same thing again, it ran good for 2 sessions and now its back to acting like poop... i tried the above method of fuel pump cleaning (took it apart and cleaned the filter) and this didnt help my problem... i want this thing to be agressive on the gas not that it acts like its drowning ![]() pretty sure its nothing electrical cause otherwise it would not ran good for 2 sessions.. dunno if this is a air or fuel problem ![]() somebody chime in for assistance please! 636 bog when hot - Gerlach - 06-03-2011 I'm still having the same issues.. I changed the coils, put FI cleaner, put a silencer in my exhaust for back pressure, changed plugs, I thought maybe it was getting too much air so I blocked part of the air intake, tried running at different rpm's. ALL of this did nothing... I think it may be in the fuel cause it seams like it's not getting any on low end. This is getting to be an expensive problem. and annoying. Next on the list is new fuel pump, fuel filter, air filter, and throttle body's... and an empty wallet 636 bog when hot - Gerlach - 06-03-2011 Well I talked to my friend who's a car machanic.. He's convinced I still have a bad coil that bench tests good but once heats up is not running enough ohms. I road a 636 with a bad coil and it ran way worse than this.. Is it possible for a coil to be a little bit bad or is it all or nothing??? 636 bog when hot - richd3000 - 06-03-2011 I'm an auto mechanic, yes coils do read n act fine when cold n go to shit when hot n under a load... n some barley cause a noticeable problem, loss of power or erratic idle, and some just cause a horrible skip n make the motor barley run at all. Def worth getting a set n swapping since they on eBay for about 50 bones... |
