Triumph 675 - new cage design - Twite - 10-08-2010
Originally Posted by old man roger
cool i like to make them so the slider and that bend hit at the same time but i would probably add a piece from the first bend to the swing arm bolt
I know exactly what you mean. I considered it. There's a few things I could do to make it stronger, but I'm trying to stay minimalistic.
This is kind of an experiment. It's really light right now and if I don't have to over-build it I don't want to.
Triumph 675 - new cage design - JohnForLife - 10-08-2010
looks good.
Triumph 675 - new cage design - old man roger - 10-09-2010
i hear ya and i started the same way but every time the first bend hit the ground really hard like a pancake or some thing like that it moved in so i added the extra piece ..
i also did some thing a little different, to keep all the force from being put on the all thread instead of making the mount at the swing arm bolt just a flat piece i made it a 90* so it not only sat flat on the frame but it also sat against the side too ..
Triumph 675 - new cage design - Twite - 10-09-2010
Indeed...and there's a chance I may have to do the same.
I've also considered taking pieces of round tubing who's inside diameter matches the outside diameter of the frame mounts, placing them so they "cup" the frame mounts and distribute force over a larger surface area. Kind of hard to explain...
Triumph 675 - new cage design - dlish - 10-09-2010
theres a wrecked s title in tampa area $1800. too far for me so someone else go for it
Triumph 675 - new cage design - B. Kerr - 10-09-2010
nice.. love the 675! I used to rock my buddies stocker - felt great would love to have one for a stunt piece..
yup i know what ya mean , i see the all thread breaking on alot of cages that use the swing arm bolt so any thing you can do to redistribute the force will help , dont usually see any problems on the motor mount bolts
I've never had trouble with the bolts or all thread breaking. I check it often and tighten when necessary.
My concern is the cage folding up.
Triumph 675 - new cage design - El Sammo - 10-10-2010
looks good man, light and strong like a muah thai fighter ha
Triumph 675 - new cage design - Twite - 10-10-2010
and sexy like a Thai she-boy....right?
