636 ? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 636 ? (/showthread.php?tid=12632) |
636 ? - troy - 03-20-2010 cool thats the i didnt do i try that see what it does 636 ? - troy - 03-20-2010 have any no how to make the 04 636 fan stay on like the f4i bypass wire that you can do the f4i are easy to do but 636 i cant find it to make stay on
636 ? - old man roger - 03-20-2010 there are two wires going to a sensor on the left side of your radiator , leave them hooked up but put a switch in between the two wires so if you forget to turn the switch on it will still turn on at the factory setting .. 636 ? - troy - 03-20-2010 temper sensor thanks bro i try it not 636 ? - troy - 03-24-2010 thank for help it ran perfect now not really having boging problem appreciate it OLD MAN ROGER
