how much psi to run for 0's - Printable Version
+--- Thread: how much psi to run for 0's (/showthread.php?tid=9411)
how much psi to run for 0's - 12oclocker - 12-23-2009
stock pressure works good.
how much psi to run for 0's - T-Dubby - 12-23-2009
Originally Posted by tru1rydaz2220
yea i went up to 30 and it feels super funny but guess i just have 2 keep riding it like that
Yeah it'll be squirly for a bit then you get used to it. i'm usually like 27 if it goes down it makes it hard to circle
how much psi to run for 0's - BIGBEN954 - 12-23-2009
Originally Posted by big ben
40 all the way!
+1 anything less than 36 makes em hard to turn, fells like its on the side of the rim. Just set it high and get used to it. If you try to bump it up every couple times you ride youll be fighting getting used to it every time. 40 will feel weird as shit at first exspecially if your still at that fighting to turn stage but itll be all worth its while in the long run!
how much psi to run for 0's - SDFKILLZ - 12-23-2009
Originally Posted by BIGBEN954
that would really depend alot on your weight and the tire choice. i weigh in at 160lbs and 30lbs for me on the tires i run is plenty, i get no tire fold or sag when doing circles. someone weight 200lbs might need a bit more but you cant generalize tire pressure for everyone with every tire
how much psi to run for 0's - SBS Pez - 12-23-2009
Originally Posted by old man roger
+ 1
40psi!! Sh1t ive been at 22-25 for about 6 months better get pumping
how much psi to run for 0's - old man roger - 12-23-2009
Originally Posted by SBS Pez
just put it at 40 and get used to it , you will love it once you do
how much psi to run for 0's - krazykyle85 - 12-23-2009
Originally Posted by SIC J
its personal preference. don't think anyone now a days run lower than 25 anymore
jorian killed it the whole time in NY with 16 PSI! he didnt worry about it.
but he said normaly he prefers 2 bar which i think is 25 psi?!
37+ PSI rear here
how much psi to run for 0's - armenian. - 12-23-2009
i run 5 psi wassup
how much psi to run for 0's - big ben - 12-23-2009
i got a new tire with a lot of curve on it..... i had to lower the psi to 35 but found if you dip it in in flamingo u can use yor leg to help shift your weight.... i worked for an hour trying to not low side in SS but kicked that leg out helped getting used to it really fast.
Originally Posted by SDFKILLZ
Well im 6'6 280 lbs, thats why i need 40!
