Fiddy Repair and Maintenance. - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: 50 stunts (https://stuntride.org/forumdisplay.php?fid=21) +--- Thread: Fiddy Repair and Maintenance. (/showthread.php?tid=59) |
Fiddy Repair and Maintenance. - yamahareco - 12-29-2009 haha ıt will be ok Fiddy Repair and Maintenance. - nj636 - 01-04-2010 my boy has this bike. down low it sputtered but up top it's ballsy. I messed with the mixture screw and that made it stuntable. as for taking off on it's own, is the throttle sticking? Fiddy Repair and Maintenance. - sivadnivek24 - 02-14-2011 fifty.jpg Fiddy Repair and Maintenance. - always.anthony - 09-05-2011 anyone know how to straight out the front wheel? i tried loosening everything, then straightening out the wheel, then tighten it but it keeps going back to being crooked. Fiddy Repair and Maintenance. - Stick - 09-05-2011 I always butt it up against something and turn the bars. Or, hold the wheel between my feet and turn the bars. Stop crashing and it'll stay straight. Also, this thread is mega old. Fiddy Repair and Maintenance. - always.anthony - 09-05-2011 i got em crooked ![]() but i guess i'll try again thanks Fiddy Repair and Maintenance. - Crazy D - 09-05-2011 Something has spun inside one of the forks , lower busshing is worn and sloppy , the upper retainer is worn , or the spring has shifted inside . Go watch the suspension install in tech support on 50stunt . it will show you everything that is inside your fork tubes . Fiddy Repair and Maintenance. - always.anthony - 09-06-2011 this is what i was looking for thanks dude! Fiddy Repair and Maintenance. - irish rider 17 - 12-19-2011 Can anybody help me,I did an endo on my crf 70 and my knee hit the throttle cable. The idle shot way up,i moved the cable back and forth to solve the problem but every time i move my handlebars to the right my throttle shoots up and when i go to the left it goes down? any advice would help. Im sure its something simple, but any advice would be appreciated.Thanks Fiddy Repair and Maintenance. - BirDMaN420 - 12-22-2011 Could possibly be the way you've routed the throttle cable from the throttle to the carb. When u turn right it's pulling on the cable. My bike does the same but only very slight and i need to turn the bars quite alot to the right |
