Linking calipers?? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: Linking calipers?? (/showthread.php?tid=53804) Pages:
Linking calipers?? - standupnfall - 12-28-2015 That looks like a lot of nonsense. Just run 1 line to each and you will have a good setup. R1 master to an f4i 4 piston is a proven setup. Linking calipers?? - Clutchup - 01-28-2016 Haven't replied in a while I have put back to normal and works good I since replaced my rotor and new HH pads seams good Sent from my iPhone using Tapatalk Linking calipers?? - MadAntZx10R - 02-01-2016 I am trying to find a handbrake setup for a 2014zx10r somehow... is it possible to set up the handbrake into the stock caliper or do you have to get a bracket and 2 caliper setup? Linking calipers?? - Clutchup - 02-01-2016 Yes you can get an adaptor setup and tap a hand break into your stock rear master. They don't work that great tho unless you bleed it perfectly so you don't have to pump up the brakes also need a good master (16 mm-13mm) Sent from my iPhone using Tapatalk |
