Tricky technical question - Printable Version
+--- Thread: Tricky technical question (/showthread.php?tid=52899)
Tricky technical question - MikeM - 06-18-2014
I can see how raising the front end would raise the COG slightly, but the way I see it, having 'longer' forks would put the COG over the front axle at a lower tail height.
To know for sure, we'd have to look at a diagram with the rake angle of the forks and the line from the contact patch to COG charted together.
Explain to me how raising the rear suspension makes a huge difference. I imagine it would be closer to bp from the start, but once the rear is off the ground, the only difference would be that the rear axle would be down and further back making the bp maybe slightly higher.
The start is the most important part. Thats where the most speed is lost, and thats when the angle changes quickly. But the relativity to balance point isnt even the biggest benefit, traction is. Obviously the front will have more traction since the bike is already leaning forward a little. More traction means you can hit the brake harder at the start, and get it up quicker. Up here in the north, thats a big deal in the winter.
Tricky technical question - loogie - 06-18-2014
Quote Originally Posted by maverickxp
Wow wonderful advice there kemosabi. Now stfu and go back to Facebook stalking like a good Lil bitch
To give a better description of what happens. Lowering the front end brings the wheels closer together the closer together they are the higher the balance point will be. For an experiment try balancing a broom stick by staring only at your hand. Then try it again but look at the other end of the stick. It will balance better the further you look up the stick. Same basic principle. If your forks were 10ft long the balance point would be substantially lower.
Nice to see loogie passed physics 101.
LOL I don't even have a Facebook you fotf faggot so not sure what your referring to and furthermore the only "lil bitch" on here is you posting up fake vids and going on how you make 120k$ a year yet you own a bunch of garbage bwhahaha. I think I just got dumber replying to you as well. Bang head to wall.
Tricky technical question - broham - 06-18-2014
Quote Originally Posted by Ridick_Bowen
Won't lowering your forks make initiating stoppies easier? Less compression during pop up? That was what I experienced.
Bill D explained his suspension set up as having soft compression so that the bike dives quickly and stays compressed throughout the stoppie. But he didn't mention anything about ride height in the front or rear. But I think you're right about lowering the front end and having less compression during pop up
Tricky technical question - Stubbz63 - 06-18-2014
^^ that would make sense just like raising the rear, if you only lower the front the rear is actually higher and will lift easier. I had a 636 lowered just slightly and it hated stoppies.
All in all no clue i'm only here to read loogies comments lol
Quote Originally Posted by MikeM
we can assume that the contact patch will always be directly below the axle. The rake angle can change depending on ride height in front or rear, but the angle between forks and frame will always be the same, so once the rear tire is off the ground, rake angle doesn't matter any more. I drew some lines on this picture to explain why I think BP would be lower with a raised front end.
so it sounds like a bike with a raised rear and a lowered front would come up easily and have a super tall BP
Tricky technical question - JBoom - 06-18-2014
Just curious but would messing around with the front suspension whether going lower or higher now change the BP of a wheelie?
Tricky technical question - maverickxp - 06-18-2014
What do you mean by changing the suspension. You mean the settings or height
Yah the height. Sorry
