09 ZX6R Strange Whirring Engine Noise - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 09 ZX6R Strange Whirring Engine Noise (/showthread.php?tid=51273) |
09 ZX6R Strange Whirring Engine Noise - SQUINTS - 10-10-2013 I dropped mine kinda hard on the right side and had to replace starter cover... I don't know man I kinda thought vacuum or something too but it's def a weird noise 09 ZX6R Strange Whirring Engine Noise - Duane S. - 10-10-2013 make sure the coils are all pushed in and good..... check seals all around the motor and gaskets sounds like the motor is sucking in air 09 ZX6R Strange Whirring Engine Noise - loogie - 10-10-2013 Sounds like a hopped up vacuum cleaner 09 ZX6R Strange Whirring Engine Noise - vegasrider2005 - 10-10-2013 Jersey street ride? 09 ZX6R Strange Whirring Engine Noise - DeNoZZo - 10-10-2013 Update- I think I've got it figured out, we isolated the sound to the stator cover. We tested the stator and found out it wasn't putting out as much as it should, and that it was shorted out. After pulling off the cover we could see it was all burned up on some of the coils. Anyone know if I should fork over $300 for a new oem stator, or if there's a good aftermarket anywhere?
09 ZX6R Strange Whirring Engine Noise - maverickxp - 10-11-2013 Yep stator took a poop on ya. Go oem. Ive used the ricks stators and they are garbage 09 ZX6R Strange Whirring Engine Noise - SQUINTS - 10-11-2013 Yup lol.. My bike has 8k miles on odometer which seems low. it's weird the stator would burn out like that 09 ZX6R Strange Whirring Engine Noise - sikgixxer750 - 10-11-2013 You can find oem stators brand new for 200. Buy that over a ricks. 09 ZX6R Strange Whirring Engine Noise - DeNoZZo - 10-11-2013 Where? The lowest I've found online was $219. I would happily spend the extra over a ricks and get an oem 09 ZX6R Strange Whirring Engine Noise - SQUINTS - 10-16-2013 Any update?? |
