06 636 bog and wont start!!!! - Printable Version
+--- Thread: 06 636 bog and wont start!!!! (/showthread.php?tid=47124)
06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-05-2013
Quote Originally Posted by Shockey
drain ur current gas and put fresh in also.
ya shockey i know my fuel filter needs cleaned bad, i plan on doin that to while the bikes down!!!
another thing i had goin on that i forgot to mention is that my stator wasnt charging the battery, if i bypassed the yellow and black ground wire and ran it straight to the battery ground it worked like a champ, i think i may just need to get a wiring harness but really dont know what would cause all the grounds to melt down like they did ???
06 636 bog and wont start!!!! - DoWheelies - 02-06-2013
did u think to change the plugs? lol just checkin...
06 636 bog and wont start!!!! - DD_636 - 02-06-2013
Quote Originally Posted by DoWheelies
that is what i was going to say. sounds like it needs a good tune up. i change my plugs 2-3 times a year as cheap as they are its worth it in my opinion.
06 636 bog and wont start!!!! - RYAN SMITH - 02-06-2013
open circuit to ground. got a meter?
06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-06-2013
Changed the plugs twice, cleaned the air filter and everything
Quote Originally Posted by RYAN SMITH
Ya i checked the ground and its bouncing all over the place, i bought a main harness today, what im afraid of is hookin the new one up and this happening again, i was told it could be my rectifier but idk how to check that
checking the reg is easy, but doesnt sound like a charging problem. ohm out each leg, shouldnt have a reading with the leads reversed. check there is no short to ground from the stator as well
06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-07-2013
ya, im wondering if since the grounds were all melted that was causing my charging issue! i bought a new harness yesterday so that should be arriving saturday or monday at the latest
06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-10-2013
just so everyone know i changed out the wiring harness and it worked like a champ!!! thanks to everyone for the help!!!
