thermastat 636 replacement - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: thermastat 636 replacement (/showthread.php?tid=44995) |
thermastat 636 replacement - Duane S. - 11-12-2012 bike just over heats to much its just weird thermastat 636 replacement - SQUINTS - 11-12-2012 Put a new radiator on thermastat 636 replacement - old man roger - 11-12-2012 If you have 2 fans and no air in the system then it sounds like you have a bad thermostat. That's assuming your fans are blowing air in the correct direction, there isnt anything restricting the air flow and there isn't any thing restricting the flow of the coolant. thermastat 636 replacement - Duane S. - 11-12-2012 it is a new radiator the radiators I have r pretty much mint thermastat 636 replacement - lee majors - 11-12-2012 easy way to check the thermostat. if one hose stays cold after the bike is completely warmed up, then it bad thermostat. if both hoses eventually get warm...its not. thermastat 636 replacement - old man roger - 11-12-2012 You can have two hot hoses and a bad thermostat. thermastat 636 replacement - JohnnyP - 11-13-2012 take it out suspend it in a pot of water on the stove and test it, all you need is a good thermometer between 58 ∼ 62�C (136 ∼ 144�F) it should open I have fixed overheating 636 in the past by swapping them out, they do go bad sometimes thermastat 636 replacement - stunt305 - 11-13-2012 + 1 thermostats are easy to test pop that bitch out thermastat 636 replacement - stunt305 - 11-13-2012 before spending a penny thermastat 636 replacement - ROWDY - 11-13-2012 THIS!
